Power supply advice
CN0TE
Despite this being my second computer build, I still find figuring out the right Power supply to be a challenge. Based on this build what wattage/amps do I need? Thank you in advance!
Intel Core i7-3770K Ivy Bridge 3.5GHz
ASUS SABERTOOTH Z77 Motherboard
ASUS GeForce GTX 680
G.SKILL Ripjaws X Series 16GB DDR3 RAM
Koutech Internal Card Reader
OCZ Vertex 3 120GB SSD
Western Digital 500GB 7200 RPM Internal HDD
LG Internal Blu-ray/DVD/CD Drive
COOLER MASTER HAF X Full Tower Computer Case
Windows 7 Professional SP1 64-bit
Also, what do you think of the build? Comments, suggestions, compatibilities?
Thanks again!
A good quality 650W would do you fine with alittle overhead. Stick with XFX/Antec/Corsair/PC Power&Cooling/Seasonic/Silverstone
Iv always been told that PC Power and Cooling makes the best power supplies, but Iv never seen one nor owned one.
But I would agree 650W should do it. As that setup isnt too different from mine (power wise), probably is actually more power efficient than mine with the IB CPU.
Using one now, the older 750W Silencer S75QB. They have changed alittle in the last couple of years, OCZ bought then out. The MK II series are made by Highpower, good power supply but alittle lower quality then the seasonic models. The MK III series are still made by seasonic. The newer Silencer series, 760/910W models are seasonic models. The Turbo Cool 860/1200W are made by Win Tack, excellent units too.
