Anyone have experience with Sagers? Deciding between two...
knockout34
Both are nice, I cant help but wonder about the 'upgradeable' nature of the GPU is decided at time of purchase-- not upgradeable later unless you replace entire mobo, etc..
Not sure though??
To answer your other query-- I dont think $200 extra for a flashy keyboard is worth it.
Sager is a respeccted brand, but do you REALLY need it to be portable?
Unfortunately yes. Believe me, as soon as I am able to have a gaming desktop I'm building my own. For now though I need something that I can game on respectably that will travel with me.
And Laquer Head, from what I've read, even after purchase they are upgradeable as long as you have a compatible GPU. From looking at the inside, it's just held in place by 4 screws. Actually looks pretty simple compared to what you normally have to do to replace a notebook GPU.
..And Laquer Head, from what I've read, even after purchase they are upgradeable as long as you have a compatible GPU. From looking at the inside, it's just held in place by 4 screws. Actually looks pretty simple compared to hat you normally have to do to replace a notebook GPU.
Thats cool, I honestly havent seen a GPU chageable laptop before.. take pictures if you do--I'm very curious now
Sure thing, might take a while though. In the meantime, this picture shows the interior, with the 4 screws circled. And opening it up and swapping pieces doesn't void your warranty with Sager.
