Can This Computer Run These Games With High Fps
Mr Bubbles
Could this run games like Team Fortress 2, Minecraft, Arma 2, etc. Well?
2.6GHz Processor
4GB DDR3 RAM
ATI RADEON HD 6570 1GB Graphics Card
what kind of processor is it? that will determine a lot. A pentium 4 @ 2.6 will not. Core 2 @ 2.6 is getting there. core series will run it fine. Graphics card is weak. You could probably get low to medium at a good FPS depending on the game.
That will run Arma II okay. I got pretty good settings with a 4870 and G530. Your graphics card is your bottleneck. It is very weak.
Corsair 430CX 430W is the power supply, also will ATI RADEON HD 6570 1GB run tf2 decently? trying to choose between the 2 because the Radeon is cheaper
the 6570 is a upper low range card. It is not really meant for games. you want at least a 6750 or GTS450. If price is an issue, you can catch working models on ebay all the time.
As mentioned, the GTS 450 is the faster card. A CX 430 will power a GTS 450 just fine, so I'd say if you can, go for one of those. There are probably loads of second hand 450s going for cheap on eBay if you look around a bit.
