wait, he wants to run 4 monitors and it has 3 connectors. how will that work?
fail.
You can only run 2 cards if they are SLI or CF compatible. you can not run that card in SLI, because of the lack of the connector. Plus not that it matters, but if you add up two, they are no where near as powerful, and $8 more expensive + shipping.
GTS 450 and above are the ones that can run SLI I am pretty sure of it.
The system will not output to 2 card at the same time unless you put them in SLI or CF unless you run one as physics will you won't need as your not gaming.
SLI does more than just combine the cards. It also enables (except for the GTX590, GTX670, GTX680 and GTX690) nvidia surround, which will allow the use of more than 2 monitors on a single card.
AMD allows eyefinity, the use of more than 2 monitors, with single cards as ling as you get one with the right number of ports.
It does not work that way. You can only use the slave cards ports after the primarys displays are used. But don't believe us. But what you want. Its really getting old when we give people advice and they believe they know everything. If you knew what you wanted and how everything works, then please pray tell why the heck did you ask for help?nVidia cards are limited to driving 2 independent displays per master GPU I thought? When you enable SLI, one GPU becomes a slave to the other, and is no longer capable of driving independent displays.
fail.
