Got my 3570k in today, so far so good but;
on CPU-z my multiplyer is basically stuck at x16 if i'm not doing anything, but goes to x34 with prime, etc.
Speedstep is disabled.
Please help!
Thanks
Disable if you have it/Turbo/C1E/EIST/C3/C6
I can't seem to disable Turbo?
ASRock Extreme4
If that is the Z77 extreme 4, then you pretty much wasted the money on that board. Support is horrible, the BIOS is confusing, and most of all it is not a quality unit.I can't seem to disable Turbo?
ASRock Extreme4
I have the Z77 Extreme 4 awesome board so far. On topic:
Disable SpeedStep and C1E. The latter is under Advanced Cpu options in UEFi if recall correctly. I just went to the same thing OP os going through yesterday.
@wolfe : its not BIOS its UEFI now. And I can disable Turbo and unlock the multiplier just fine.
Go into windows power options and turn it to performance?
No help
Let me retract and say that we both are right technically. The board is picky. Don't know what I did different last time, but it booted fine this time using teh 480, 2600k and 212 evo. Hooking up my HDD to see if I can save the install.@wolfe : its not BIOS its UEFI now. And I can disable Turbo and unlock the multiplier just fine.
