RebeccaOwen
I have a Toshiba Satellite A665-S6094 laptop and I'm having serious issues.
Here's some specs (if necessary):
Win7 Home Premium 64-bit
Intel Core i7-740QM Processor, 1.73 GHz (2.93 GHz with Turbo Boost Technology), 6MB Cache
Mobile Intel HM55 Express Chipset
NVIDIA GeForce 310M with 512MB GDDR3 discrete graphics memory
Total Available Graphics memory 2270MB
4GB DDR3 (max 8GB)
640GB (5400 RPM); Serial ATA hard disk drive
TOSHIBA Hard Drive Impact Sensor (3D sensor)
My trouble is that it won't boot into Windows consistently. And when it does, it's terribly sluggish. (10+ minutes to bootup, ridiculously slow response to programs, etc.)
I might have a failing hard drive (OR a bad motherboard - not really sure). I've done a couple "factory restores" and two separate Chkdsk's (one on the bad Toshiba laptop and the other chkdsk on a good working HP laptop). Both chkdsk's found bad clusters and made repairs, yet it still fails to get past "Boot Menu" most of the time. When it does boot to Windows, it's very very slow.
In addition to doing the "factory restores", and "chkdsk's", I've also I reseated the RAM multiple times. Tried different RAM. Took out the battery. I took out the optical drive. Took out and reseated the hard drive. I tried all of these things in different configurations and sequences and nothing has solved the bad Bootup, nor the slow response time.
So, a couple questions.
1. Other than chkdsk, is their a way to check the hard drive to see if it's failing?
2. How does one test the mobo to find problems?
4GB DDR3 (max 8GB)
