windows updated at shutdown but next time i started it did this:
QRJ
it seemed to run an update before windows booted, it was very strange, it said: applying update operation registry... there was more but the rest was not visible,
after it had finished windows loaded up as usual.
is this normal for windows 7? never seen it before and seems suspicious. google seems to yield no concrete answer.
thanks very much
Yes, it is normal for some of the W7 updates to finish installing at boot-up.
but not always?
first time it's ever happened, first time it installed them itself on shutdown too, i usually install them myself
thank you for replying
Some don't even need a reboot.
There are quite a few that partially install on shut down and finish on the reboot.
So no need to worry.
