takes a long time to connect to the internet
peter912
My internet provider told me that my computer is taking up a long time to load everything after it restarts and that's why it is taking a long time ( 5 minutes )for the internet browser to load as well .
Can I do anything about this or do I have to pay for technical help with this problem ?
Lets see whats going on with your system.
1.
Please download and run TDSSkiller
When the program opens, click on the start scan button.
TDSSKiller will now scan your computer for the TDSS infection. When the scan has finished it will display a result screen stating whether or not the infection was found on your computer. If it was found it will display a screen similar to the one below.
To remove the infection simply click on the Continue button and TDSSKiller will attempt to clean the infection.
When it has finished cleaning the infection you will see a report stating whether or not it was successful as shown below.
If the log says will be cured after reboot, please reboot the system by pressing the reboot now button.
After running there will be a log that will be located at the root of your c:\ drive labeled tdsskiller with a series of numbers after it. Please open the log and copy and paste it back here.
2.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Vista and Windows 7 users must right click on the hijackthis icon and click on run as. If the run as option doesn't appear then press and hold the shift key while right clicking on the icon to get it to appear.
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Update
This morning I got internet connection instantly so maybe this problem is intermittent ? OK, so far I have run TDSS Killer and Malwarebytes.
TDSS Killer " no threats found "
Malwarebytes " No malicious items found "
Next I will run "Hijack this" The only problem is that I don't know how to copy,paste and post . If you want me to do this then you will have to guide me through the process step by step like the last time you did so .
thank-you,
Peter in Toronto
To see the log you might have to run as administrator, you can do this by right clicking on HiJackThis and selecting run as admin. Then just copy and paste the contents of the file into your next post.
but I don't know how to copy , paste and post the HiJackThis file , that's the problem
it will be a .txt file that will open in notepad. you copy and paste just like anything else. left click in font of first letter and drag all the way to the last letter, then right click and hit COPY, then come here and click on the quick reply box and press control+V at the same time and the log will be in your response.
I have the log file of the HighJackThis scan but I can't figure out how to post it here,sorry.
I have done it in the past but I can't do it this time.
The easiest way to do this is when the log of hijackthis pops up, which is in notepad format, click on edit menu, click on select all, click on the edit menu again, click on copy. Then come back to your reply here and right click and then click on paste and you'll see the log appear in your reply.
It worked, the only problem is that this is last years scan. I'll keep trying to get the present scan posted.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:25:22 PM, on 30/05/2011
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v8.00 (8.00.6001.19048)
Boot mode: Normal
Running processes:
C:\Windows\system32\taskeng.exe
C:\Windows\system32\Dwm.exe
C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
C:\Windows\Explorer.EXE
C:\Program Files\Trusteer\Rapport\bin\RapportService.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\Windows\RtHDVCpl.exe
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\Dell DataSafe Online\DataSafeOnline.exe
C:\Program Files\Rogers Online Protection\Rogers Servicepoint Agent\RogersServicepointAgent.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\DivX\DivX Update\DivXUpdate.exe
C:\Program Files\Common Files\Java\Java Update\jusched.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Real\RealPlayer\Update\realsched.exe
C:\Program Files\Dell Support Center\bin\sprtcmd.exe
C:\Windows\ehome\ehtray.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe
C:\Program Files\WinZip\WZQKPICK.EXE
C:\Windows\system32\wbem\unsecapp.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Windows\ehome\ehmsas.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
C:\PROGRA~1\COMMON~1\McAfee\MSC\McUICnt.exe
C:\Windows\system32\SearchFilterHost.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
C:\Program Files\Rogers Online Protection\Rogers Servicepoint Agent\RogersServicepointAgentComHandler.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.google.ca/ig/dell?hl=en&client=dell-row&channel=ca&ibd=2080922
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.google.ca/ig/dell?hl=en&client=dell-row&channel=ca&ibd=2080922
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer provided by Dell
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O1 - Hosts: ::1 localhost
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll
O2 - BHO: Conduit Engine - {30F9B915-B755-4826-820B-08FBA6BD249D} - C:\Program Files\ConduitEngine\prxConduitEngine.dll
O2 - BHO: Increase performance and video formats for your HTML5 <video> - {326E768D-4182-46FD-9C16-1449A49795F4} - C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll
O2 - BHO: Use the DivX Plus Web Player to watch web videos with less interruptions and smoother playback on supported sites - {593DDEC6-7468-4cdd-90E1-42DADAA222E9} - C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20110512134348.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Vuze Remote - {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files\Vuze_Remote\prxtbVuz0.dll
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: Vuze Remote Toolbar - {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files\Vuze_Remote\prxtbVuz0.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [ECenter] C:\Dell\E-Center\EULALauncher.exe
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe"
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [dscactivate] "C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe"
O4 - HKLM\..\Run: [Dell DataSafe Online] "C:\Program Files\Dell DataSafe Online\DataSafeOnline.exe" /m
O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [RogersServicepointAgent.exe] "C:\Program Files\Rogers Online Protection\Rogers Servicepoint Agent\RogersServicepointAgent.exe" /AUTORUN
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [DivXUpdate] "C:\Program Files\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Real\RealPlayer\update\realsched.exe" -osboot
O4 - HKCU\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - .DEFAULT User Startup: Dell Dock First Run.lnk = C:\Program Files\Dell\DellDock\DellDock.exe (User 'Default user')
O4 - Global Startup: McAfee Security Scan Plus.lnk = ?
O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
O8 - Extra context menu item: &ieSpell Options - res://C:\Program Files\ieSpell\iespell.dll/SPELLOPTION.HTM
O8 - Extra context menu item: Check &Spelling - res://C:\Program Files\ieSpell\iespell.dll/SPELLCHECK.HTM
O8 - Extra context menu item: Lookup on Merriam Webster - file://C:\Program Files\ieSpell\Merriam Webster.HTM
O8 - Extra context menu item: Lookup on Wikipedia - file://C:\Program Files\ieSpell\wikipedia.HTM
O9 - Extra button: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra button: (no name) - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell Options - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~2\GOEC62~1.DLL
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\Windows\system32\browseui.dll
O23 - Service: Andrea RT Filters Service (AERTFilters) - Andrea Electronics Corporation - C:\Windows\system32\AERTSrv.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Ati External Event Utility - ATI Technologies Inc. - C:\Windows\system32\Ati2evxx.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Dock Login Service (DockLoginService) - Stardock Corporation - C:\Program Files\Dell\DellDock\DockLogin.exe
O23 - Service: Google Desktop Manager 5.9.1005.12335 (GoogleDesktopManager-051210-111108) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe
O23 - Service: Rapport Management Service (RapportMgmtService) - Trusteer Ltd. - C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files\Common Files\Steam\SteamService.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: Viewpoint Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe
End of file - 11579 bytes
Last years scan won't do any good.
Not sure why you are having issues. Open hijackthis. Click on "do a system scan and save a logfile" When that log pops up then do what I told you to do in my last post.
I am trying to reinstall hijackthis but when I go to the site I just keep going around and around without finding the download ?
Finally, success, with your help and guidance .
Scan saved at 11:55:19 PM, on 16/07/2012
MSIE: Internet Explorer v9.00 (9.00.8112.16447)
Boot mode: Normal
Running processes:
C:\Program Files\Common Files\Apple\Internet Services\ubd.exe
C:\Program Files\McAfee Security Scan\3.0.207\SSScheduler.exe
C:\Program Files\WinZip\WZQKPICK32.EXE
C:\Program Files\Common Files\Apple\Apple Application Support\distnoted.exe
C:\Windows\system32\NOTEPAD.EXE
C:\Program Files\Mozilla Firefox\plugin-container.exe
O2 - BHO: Increase performance and video formats for your HTML5 <video> - {326E768D-4182-46FD-9C16-1449A49795F4} - C:\Program Files\DivX\DivX Plus Web Player\ie\DivXHTML5\DivXHTML5.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20120622174358.dll
O4 - HKLM\..\Run: [APSDaemon] "C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe"
O4 - HKLM\..\Run: [Nikon Message Center 2] C:\Program Files\Nikon\Nikon Message Center 2\NkMC2.exe -s
O4 - HKCU\..\Run: [MobileDocuments] C:\Program Files\Common Files\Apple\Internet Services\ubd.exe
O4 - Global Startup: McAfee Security Scan Plus.lnk = C:\Program Files\McAfee Security Scan\3.0.207\SSScheduler.exe
O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK32.EXE
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O13 - Gopher Prefix:
O18 - Filter: application/x-mfe-ipt - {3EF5086B-5478-4598-A054-786C45D75692} - c:\progra~1\mcafee\msc\mcsniepl.dll
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\3.0.207\McCHSvc.exe
O23 - Service: McAfee McShield (McShield) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - Unknown owner - C:\Program Files\Dell Support Center\bin\sprtsvc.exe (file missing)
End of file - 11929 bytes
Rerun hijackthis and place checks next to the following entries.
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin \IE\rpbrowserrecordplugin.dll
Then click on fix checked.
More advice is to uninstall the rogers online protection program as you already have Mcafee antivirus. Can you tell me what processor and how much system memory is installed?
The next thing I would do is download and run Ccleaner.
http://www.filehippo.com/download_ccleaner/
Click up top right where it says download latest version. Install the program and open it up and click on run cleaner. This will delete all your temporary internet and system files slowing your system down.
I erased some of these but why would I erase RealPlayer and Quicktime, I need these ? I also downloaded and ran the "cleaner" .
You are not erasing them technically, you are just stopping them from loading in the broswer which will slow the broswer down.
