Anyone know cheap laptop batteries?
aegino
I need a laptop battery for a vaio vgn-sr590c
Anywhere good to get it?
I was wondering if any vgn-sr battery will fit?
Called Sony, and they're no help at all.
Thanks!
Found on amazon for around $60. But it says it weighs 1kg.. Wtf that's alot for a 4400mAh battery no?
Be careful shopping for a laptop battery strictly on price. You often get exactly what you paid for!
The thing about laptop batteries is that they have a certain lifespan. That lifespan starts on the day it was manufactured, not the day it gets installed. So, if a particular battery has a 3yr lifespan and sat on a shelf in a warehouse for 2 yrs, it's only got 1 yr of life left.
It says item weight 2lbs as well though. Hopefully the battery is less, this is the best bet in terms of price.
The other site suggested in this thread was asking $100
Thanks e1
Spend the money. Otherwise you'll spend more money not far down the road on a new laptop when the cheap battery fries and/or catches your laptop on fire. Believe me, I've seen it happen at work.
