mjcproductionz
I am currently looking to upgrade a PC I bought off of Newegg in late March, which wasn't the brightest idea looking back on it now. I purchased it because it was in my range and seemed to offer more than the competitors for the price. It also was supposed to come without all of the bs that often gets thrown on there, which it did; so that was a plus. I am a noob when it comes to actually toying with my own PC, but do have knowledge of PC's.
It was the CyberPowerPC GamerUltra 2123
Specs
Motherboard: A55M-HVS
Processor: AMD A4-3400 Llano 2.7GHz which is a 64 bit dual core
Memory: 2 Patriot 4GB sticks of DDR3
HDD: Hitachi 500GB SATA-II 3.0 Gb/s 7200RPM
Graphics: AMD Radeon HD 6410D Graphics
Power Supply: Apevia Turbolink ATX-TL500W-BK 12V 500W
CD/RW: Asus 24x
Case: Sigma Pluto
OS: Windows 7 Premium 64bit
Monitor: Vizio 42" LCD TV
I am going to upgrade the HDD to a 1tb and want to crossfire an amd radeon, but am not sure which one. I will most likely also be upgrading the Ram to 16gb which is the max it can hold, but probably won't do that right off the bat. I also realize I will have to change the power supply, but have no clue on what will be big enough; but am pretty sure the current 500w will not suffice. I typically bought the PC just to use Photoshop and Dreamweaver with, but would also like to play some games like Skyrim and Arkham City and no it will not be able to do what I want it to do; if it can even limp into these games.
I would appreciate advice on what type of power supply, what kind of radeon card i should get, what power supply would be the best, and who makes a decent 1tb hard drive for a fair price.
Thanks in advance and all advice is appreciated.
Specs
CD/RW: Asus 24x
Case: Sigma Pluto
