Network Hard Drive
lostsoul62
I want to set up a Network Hard Drive that connect to the router but all the review I've read are bad so does anyone know of a good Network Hard Drive?
I'm sorry but that won't work. A network anything has a RJ45 that goes into the router so you can access it from any computer while all the other computers are turned off. Also how about a wireless Hard Drive which doesn't need a router?
The network sharing is what the usb ports on the router are for! You plug the hard drive into the router to share it.
Otherwise have a look at this :
http://www.amazon.com/Seagate-Satellite-Wireless-External-STBF500101/dp/B004Z0S7K6
Did you look at what he linked? It clearly has 2 USB ports and supports USB storage media.
I'm not looking for USB storage area, I already have 4 external Hard Drive with USB, I'm looking for Network Hard Drive which you plug your Ethernet cable into the Hard Drive and the other end into the router. My question is "Are there any Network Hard Drives that have good reviews"?
All the responders understand what you mean. There are newer routers that allow drives to be connected via USB that can then be shared on the network. What you are talking about is called NAS (Network Attached Storage). Check here: NAS
