Please approve my build before I order
wal-dog
First time builder, first time poster. I don't game but would like to build the best system I can for less than $800. All this comes to $745. The motherboard I picked is an AM3+ socket and the processor is is AM3. Will they work together? Let me know if I should change anything. Thanks.
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM SATA 12X Blu-ray Burner with Blu Ray 3D Feature IHBS112-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106369
In b4 Wolfe says don't get the Cooler Master 912.
Looks good. Did you consider a FX Series Processor rather than Phenom II though?
guys help me also before i buy new CPU., my budget is maximum of 1000$ us dollar for a CPU. and i dont have enoughk knowledge to set up a good CPU. but i tried, please take a look and recommend some changes and additional parts.,
Also, remember that oem "windows" can only be for 1 machine, can not be transferred. I would rather buy retail.
