Hihi.
I've mentioned this to some of you pros, but neither could help me.
I have overclocked my AMD FX-8120 to (so far) 4.3 GHz. Seems stable so far, will try for a bit more eventually.
In any case, when I run Prime95 blend test to stress test the machine, CPU-Z says my core speed is anything from 1999 (just saw that, a new low) to 5600 MHz. It just swings around wildly all the time. When I am idle it says 4.x (whatever I was overclocked to before) as it should be. When running SmileMan's and spirit's benchmark it says the correct speed until the end where it goes down a bit before finishing. It doesn't swing as wildly, nor does it go above the set speed.
Why does it do that? I have, as far as I know, everything disabled that should be disabled in BIOS.
For those that have disabled signatures, I have a Gigabyte GA-970A-UD3. My BIOS version is F4, and I hope updating that won't help because setting up this clock will be annoying.
Any way to fix this?
