|Official|Black Hole: Benchmark Ranking thread
not really. I want faster RAM as is because my render times went down when I OCd to 1866, so I could get the fastest times with 2133. I think that is the fastest that my board supports.
Water cooler is just to bring temps down some more. I am stable at 4.7 right now, but it is 77* average on average load temps. I want to bring it down, and hit 5GHz too.
I can't give you the trust that you'll hit the 9000. Because cpu's got oc limits from where it will not increase performance anymore...
well I am already at 8850, so faster RAM and a bit higher clock will get there most likely. If not, it will still definitely be either the top score or 2nd best.
And not to knock the knowledge, but that does not make any sense at all. If you make it stable and faster, performance goes up. 5GHz does more work than 4.5GHz every time, unless it is not stable.
Yep, but up to 5ghz will be more difficult to get it stable. (Tried it with stock cooler, ran prime, saw my temperature going above 90 ;p)
But I got my fingers crossed for you. :D
probably either H80 or H100. Not sure yet. Depends on if I go for a new motherboard with it or if I just grab RAM and a cooler.
That is mainly, as long as memory serves right, because they have about the same area. The 80 is double thick, but still only a 120. The 100 is single thick but double fan. Either should do, but I still like the idea of 2 fans for top exhaust.
Yeah, it has his advantages.
The fans are loud have I heard, but if you are like me, I don't give attention to that.
