What will fit in CoolerMaseter 430 elite
Maximum Compatibility VGA card length for CoolerMaster 430 elite -(315mm / 12.4 inch)
You should pretty much be able to fit any current card in there,Even a HD6990 or GTX690 will fit and they are LONG! :)
Thanks :), Im thinking about getting a HD 6850 because by this time next year im going to have a triple monitor setup :D.
With a little more money I would go for a hd6870 or a hd6950. Because it's not much between the hd6870 and the hd6950. The hd6950 is a good buy this times.
for a triple monitor setup you must at least have 2gb memory on the gpu (if you gonna play some games).
Actually the 6870 looks really good and suprisingly I could get it cheaper than the 6850. By the way how is the 6870 in crossfire ?
