Its not going to be great. your running 1333 RAM and a dual core and so far everyone running here is on at least quad cores.
plain and simple he wont hit 4GHz, let along 5GHz. It is a sandy bridge i3. 100 MHz, maybe 150MHz is all your going to get.ram doesn't make that much sens, maybe 100-150 points max. And that i3 has 4 threads.
If he can clock it to 5ghz, it will be a decend score I think.
^ Exactly. You cannot really overclock an i3 at all, they are not multiplier unlocked.
haha, hmm I see, he had an i3 once oc to 5ghz. But not the one he has now...
That was a Clarkdale i3. It wasn't a stable overclock though, and it was done using software, not through the BIOS.
But he slashed a great score in my app with it.
He did but it wasn't an overclock he'd be able to keep really. I can't remember how high he had his voltage in order to get it to boot at 5.0GHz, but it was pretty high IIRC and we all know that more voltage = more heat.
yep, I know >:S
He had in the 1.5 for voltage![]()
Ill try this on my rig later tonight![]()
...Laquer Head is still leading the top!
He will probably keep it for a while too. Im running 4.1GHz right now, but I can say for sure that I tap out on this board at 4.7 to 4.8 depending on the day. New build with a new cooler should clock better.
hmm... I'm going to try 5GHz at 1.5V right now and see if I can run the app. If it don't then there may be an issue with the app. It is interesting to see that you can't. So I guess what I am saying is I am going to try and reproduce the problem and see what happens.
nope. And it won't boot at that voltage.So I said screw it its at stock now till my SSd comes in
