monkey magic
Hi folks,
I'm trying to do a clean install on my computer as I forgot the password for the only account
So I set it all up, put in the disc and set the DVD drive first in line for boot up.
I get the messege "press any key to boot from cd or dvd" and continue.
Then I get the "Windows Installing" bar and after that the splash screen comes up.
Here's where it got messy. After the spash screen I get a blue screen.
Now I'm stuck, can't find anyway around the blue screen and have no idea what to do. Can't even get onto the old windows anymore.
Please help!
Thanks in advance guys.
Blue screen Quote
A problem has been detected and windows has been shut down to prevent damage to your computer.
An attempt was made to write to read-only memory
If this is the first time ... If this screen appears again follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
*** STOP: 0x000000BE (0X9177FEA4,0XC8E72900,0X88586B18,0X0000000E)
Didn't know what you'd need so put in everything. Should tell you all in advance that I'm not amazing with computers. Thanks!
Please help!
Blue screen Quote
