Stock fan on CPU?
forge117
HELLO EVERYONE...
I just finished another gaming rig and i was curious if i really need to upgrade the cpu fan.. my specs are as follows...>> I use this rig strictly for gaming......NO OVERCLOCKING INTENDED........Please advise THANKS :)
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
Rosewill THOR V2 Gaming ATX Full Tower Computer Case, support up to E-ATX / XL-ATX, come with Four Fans - 1 x Front Red LED 230mm Fan, 1 x Top 230mm Fan, 1 x Side 230mm Fan, 1 x Rear 140mm Fan-Retail
Rosewill HIVE Series HIVE-650 650W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, ATX12V v2.31/EPS12V v2.92, SLI Ready, Cross Fire Ready, Active-PFC Power Supply
ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core
SAPPHIRE Vapor-X Radeon HD 5770 1GB (LIL OLD BUT ROCKS BF3 ON HIGH)
If you're not overclocking it should be fine, just watch your temps though.
ok thanks and watch the temp with cpuid?
also would you know about why my g skills ram is only showing 1600 mhz and not 1866 mhz? i called asus and tried some changes in bios but still falls back to 1600 ...i dono... I would like it at 1866 mhz but if theirs no major difference
then i will just leave it... thanks for your help :)
Post a CPU-Z screenshot of the memory tab. Are you RAM is definitely 1866 and doesn't have to be overclocked in order to reach 1866?
i am not home right now, i will post cpu-z tab of ram later on today. i am at work till 7pm est, yes this is the ram i bought from newegg.
only showing 1600 mhz, in bios. when i switch it to 1866 it seems to have dropped to 1333...odd..
thanks for help..
thanks for help..
hey guyz..
OK so i called g-skillz and got the settings to make my ram is it as full 1866.
had to adjust bios settings timing and voltls. and command rate.. and cpu-nb volt....after i did that shes seeing 1866.. :)
awsome... know, question.... If i wanted to play with overclocking my cpu were would i start.? also do I need to upgrade my stock cpu fan/heatsink??
if so ... what do u suggest... just curious... thanks again for help
forge117...
