WeatherMan
Hi guys,
I've forgotten to make a thread on this from when I first noticed this problem.
I have a 8ish year old laptop made by E-Systems, not a very powerful system, I think it has a Intel Celeron 585, 1GB ram, Vista blah blah.
Anyway, it gets extremely hot, and I have no way to open it up and clear it out to reduce the temps, as it's kind of a sentimental system, my stepdad doesn't want it fiddled with at all.
CPU idles at around 60-70cc, loads at around 85-90c
Since I first noticed the laptop getting extremely hot, I've seen that the battery has expanded a lot, so much so that the rubber feet that the whole laptop sits on are wonky because of the base not being straight. The curvature of the battery is now bottoming out the underside of the system, so that it does not sit flat.
I ran HWMonitor yesterday and noticed that there is a 97% wear rate on the battery. It now holds no charge at all.
It did used to last around 5 minutes, and at that time IIRC it wasn't bulging.
Anyway, should I be concerned?
I can use the laptop easily just on AC power, but it's kind of awkward with the battery removed, the weight distribution shifts, and it's base obviously uneven due to the hole where the battery is supposed to be.
I will most likely replace the battery eventually, but have no need to right now, what I want to know is why has this happened, because of age, wear rate, heat?
Also, I've heard a few horror stories about exploding laptop batteries, most likely due to heat? Would it be a good idea to remove the battery?
Thanks
Thanks
