upgrading.
emd023
I would like to have an hdmi slot so I can hook it up to the tv. any suggestions for a new motherboard? can i even transfer my cpu to new motherboard? I do not really want to spend over 100 bucks.
- Quad-core AMD Phenom II 940 Black Edition 3.0 ghz
- 4GB ddr2 ram
- ATI Radeon HD 4870
- 600w psu
Please post your exact specs. Do this by downloading and running PC Wizard from my sig. Go to FILE, SAVE AS and click OK. Copy the contents out of that text file into this thread. Also post what PSU you have. It will be better in all likelihood to simply get a new GPU.
<<< System Summary >>>
> Mainboard : BIOSTAR Group TA790GXB A2+
> Chipset : AMD 780
> Processor : AMD Phenom II X4 940 @ 800MHz
> Physical Memory : 4096MB (2 x 2048 DDR2-SDRAM )
> Video Card : ATI Radeon HD 4800 Series
> Hard Disk : SAMSUNG HD103SJ ATA Device (1000GB)
> DVD-Rom Drive : Toshiba-Samsung CDDVDW SH-S223F
> DVD-Rom Drive : MagicISO Virtual DVD-ROM
> CD-Rom Drive : DTSOFT Virtual CdRom Device
> Monitor Type : HannsStar Hanns.G HW191 - 19 inches
> Network Card : Realtek Semiconductor RTL8168/8111 PCIe Gigabit Ethernet Adapter
> Operating System : Windows 7 Home Premium Home Edition Media Center 6.01.7600 (64-bit)
> DirectX : Version 11.00
> Windows Performance Index : 5.9 on 7.9
psu is x-power pro 600w
CPU support list doesn't show that cpu, id say save your dough and get something more significant. Its a AM2+ cpu, if it was a phenom ii 955 or such id say you are good, but its a 940.
if you want a hdmi a new gpu is the best thing, a new motherboard will deactivate your current windows if it is an oem version and that motherboard and all new ones are ddr3 so new ram would be required.
and that is a low quality psu, there is a chance it will blow and when it does it can take other parts with it if it sends a surge through your computer.
It can, but you are better off getting a audio cable to run to the TV from teh computer and keep the 4870. It is a fine GPU unless you are running games, and still even then. It will do BF3 at medium.
Using this method you are out less than $10 to get your system to go to your TV, and you will never match your 4870 for $10 period.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812270286
http://www.newegg.com/Product/Product.aspx?Item=N82E16882678020
im going to go ahead and do that. thanks guys
Your next spend needs to be a new PSU.
Although it will work, running a 4870 on a PSU with only 30A available to it and other components (except the CPU) is silly. Thats only 360W running a card that by itself uses 160W and thats without overclocking.
If you have the coin, upgrade the PSU.
