Asus P8Z77 with i5-3570K
swchoi89
Hi,
What do you guys think? Do you think the 3570k will better perform with other motherboards or will perform just as well without being noticed?
Thanks
It should be fine, but a gigabyte board would be a better choice should you ever need support from the company.
What kind of 'support' are you referring to?
As far as the performance/compatibility is concerned, would I be disadvantaged for using ASUS P8Z77 in any way ?
^ The GA-Z77X-UD5H or the GA-Z77X-UD3H would be my choice over the P8Z77-V.
I think if performance-wise differences are minimal with the i5-3570k docked onto it, i'll stick with the asus board :) I think im going to sell the system in 6 months anyways... because I'm greedy haha
Btw, I finally ordered all of my parts! thanks to your help. (also getting Lexa S, how's the case for ya?)
