SSD Help >> computer freezes when changing volume sometimes
aegino
Hi,
So I noticed, ever since I installed my SSD 3 weeks ago, my computer lags so bad and/or freezes completely when I go to change my volume (this happens sometimes, not all the time).
Is there some reason why this may be happening? I think I've done all the tips for improving ssd performance on "Setup and Manage SSD" thread. Could one of these be causing the problem?
Thanks for any help!
Does it lag all the time, then sometimes freezes when you use volume control?
Or does it sometimes lag or freeze when you use volume control-
Second option
I only notice any lag when I go to hit the Fn + F2/F3/F4 to change volume settings. Changing it manually from the little icon on the bottom right of my screen doesn't lag me. Only the keyboard shortcut
Altho I don't know why, I don't think its the SSD or any of the Managements from the guide. Keyboard shortcuts. While in game? Possibly a driver conflict?
Hmm.. I went to services tried making many of the Vaio programs enabled versus disabled or manual
working well so far. Hopefully this lasts!
Thanks for the tips. I don't know why I just assumed was ssd.
Will report back if stops working again
Thx
