Ok, i want to be able to play hrrm let's say Diablo III on as max graphics as i can. Budget is really no matter. I already have a GeForce 8800 in my back up rig, with 4GB ram, W7-64bit, and a Dual Core Intel 6700 @ 2.66 GHz. This only lets me play Diablo on shitty settings though. Well, unless i want to feel like i am running through syrup.
The back up computer with a E6700 is faster then the X2 5200 your wanting to upgrade.The rig i am looking to upgrade though is currently running Vista 32-bit Business Edition (not my idea and i am looking to change it, suggestions on this will be welcome too). It has an ASUS M2NPV-VM mb, an AMD Athalon (tm) 64x 2 dual core 5200+ 2.60 GHz.
i have found it has a GeForce 6150 (which doesn't exactly help). It also only has 2GB of RAM however i'll swap the newer RAM from my back up rig to this one so it has 4 GBs.
The problem with the back up rig is that the mb can't support anything significantly better than it already has. I could throw in a new CPU but i doubt that'll help when the main problem with games like DIII for my comp is the graphics.
go to a Q6600 and you will be great. That is as much as you can upgrade to. Still a great system too.I was told it wouldn't be able to handle a better processor either which again is a big worry.
So a Quad 6600 B2 revision SLACR in the ASUS P5N-E SLI? And for the GFX card a GTX 460? Then slam the 8800 in my now back up baby? I don't like Athalon processors anyway tbqh.
With this in mind, i am only a mobo/tower unit away from a new comp as i can rip the very new and annoyingly expensive RAM out of my Intel and use all the other necessaries from one or the other. I have various H/Ds i could slap in it too. Money wise and in order to have something upgradable in the future i may be best making a new rig, no?
Then creating something relatively good as a back up from the two i have.
Core 2 Quad Q6600 (2.40GHz,1066FSB,L2:2X4MB,rev.G0,4 cores
On the motherboard's CPU supported list.
Graphics wise, GTX570 or similar.
