I have a thread right below this one but now the temperature of my CPU UNDER LOAD is around 26 degrees celsius? The room temperature is fairly cool aronud 25 degrees celcius.
Which program do you use to monitor your temps?
is it overclocked at all? CM 212+ isn't a bad cooler and those 22nm chips run really cool, or so I've heard. For reference, my 32nm i3-540 runs VERY COOL under load at 3.85GHz. 100% load on sensor test with RealTemp gets me 32 and 37C each core
It sounds like your temp monitoring program is misreading the temps. Look for a different one like core temp or RealTemp
those temps are for the individual cores, but i have trouble making sense of my temps in my i7, theres also a cpu temp i have that bounces around a bit... its not seeming to be related to the individual cores...and goes up when my load goes down, its weird![]()
