Explorer 9
voyagerfan, i have the same prob. with ie 9
i tried to uninstall from- control panel, installed updates, hi lite ie9
and then uninstall all goes well but at end - all updates not successfully uninstalled, i am running win 7-(i have done this in the past with vista and it worked-)
i've tried microsoft fix-it for ie 9, and still has problems, i've tried several restore points too and is still mucked up, any suggestions wud help- i know
diff browsers-which i use for internet, but my work security cameras only
work with ie<-- set up by independant security co. also virus scans turn up nil
thks, peter
thks, peter
Next time, please start a new thread as this is a different problem than the OP posted about.
Try using RevoUninstaller.
On Win 7, first page opens ok, Second one freeze, I can not use the Explorer, What to do? I need to use it.
Make sure you have the proper ie for your system x86/x64. I'm a webdesigner, and i work a lot with IE, but i never had this sort of problems.
