Hello members! I currently have a macbook air 2011 model which I use along with a thunderbolt display as my main computer setup. However now I want more "oomph" on my computer. The puny 4gb RAM and sloppy 1.8GHz i7 really isn't doing it for me. So I decided to build my own computer. I was looking around for hackintosh builds in order for me to run Mac OS X on my homebuilt PC. The main problem I see is just getting around the hardware support side of the Mac.. But then I want to use it alongside with Windows, which shouldn't be a problem as it's probably some really simple setting in the BIOS that I would need to change. My budget is all the way up to 1.5 grand and I live in Australia, this means that some parts may not be as easily or cheaply available for me. Now after doing a large amount of searching and searching I have come to the following hardware:
- Intel i5 3570K
- Thermaltake V9 Case
- Corsair DDR3 8GB (2x Vengeance 4GB) 1600MHz CL9 (CMZ8GX3M2A1600C9)
- Corsair GS-700 700W
- Corsair Force Series 3 240GB SSD
- Gigabyte GA-Z77MX-D3H Intel Mainboard - LGA 1155
- Samsung 22x Black Internal DVDRW
I am not sure if this build is supported by Mac OS X, can somebody please advise me.
Is it possible to still keep on using my thunderbolt display once I built this PC?
I also wish to have the ability to over clock the computer and maybe upgrade it later on (when haswell comes out), will it be possible after I finish the build?
Lastly I am not sure about the cooling that I need, I wan thinking maybe water cooling?
- Thanks!
- Intel i5 3570K
- Thanks!
