Please can someone help me - RAM?
alexjb
Hi, I decided to buy 8GB of corsair ram and it's been delivered, and will be going in my first build, but now I have a bigger budget and was wondering, can I install another 8GB corsair ram so I'll have 16gb together? or is there room for only 1 and I should stick with 8gb corsair or buy a 16gb instead?
Can I only install 1 ram or 2 rams?
Either board supports up to 32gb. of memory. 16gb. is alot of memory, any reason you need more then 8. With 8 you would have been better off getting two 4gb. sticks so they would run in dual channel. But getting another 8gb. stick it would run in dual channel.
Thank you both for your answers! :) I just checked the box for corsair and it's 2 x 4gb I think :) so that's great news! :) thanks so I can put another 2 x 4 in?
