Build
Mr.Meowgi
Hey guys, i was wondering if this parts do work with eatch other :)
MSI GeForce GTX 660Ti 2GB PhysX CUDA
PCI-Express 3.0, "Power Edition", DL-DVI-D+DL-DVI-I, HDMI, DP, w/Borderlands 2
Sony Optiarc DVD±RW Writer, AD-5280S
SATA, DVD±R: 24x, DVD+RW: 8x, DVD-RW: 6x, Bulk, BLACK
Seagate Barracuda® 1TB
SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3.5"
ASUS P8Z77-V, Socket-1155
ATX, Z77, DDR3, 2xG3+1xG2-PCIe-x16,SLI/CFX, VGA, DVI, HDMI, DP, WiFi, DLNA, UEFI
D-Link 11n PCI DWA-547 EU
PCI, 802.11n (draft 2.0)
Intel® Core i7-3770S Processor
Socket-LGA1155, Quad Core, 3.1Ghz, 8MB, Boxed w/fan
Corsair CX V2 600W PSU
ATX 12V V2.3, 80 Plus, Standard. 2x 6+2pin PCIe, 6x SATA, 120mm Vifte
Corsair Vengeance DDR3 1600MHz 16GB CL9
Kit w/4x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader, 240
Corsair carbid 400R
Do the asus wi-fi go work as the D-Link thingy to?
Pleas if there can be don changes that will make this cheaper pleas tell me :D
Corsair carbid 400R
Things that will make it cheaper: Processor. Go to a 2500k or 3570k. They will do everything just as good as the i7, but at $100 less.
Go to a HD 7870 and you will get by cheaper iirc.
Not 100% sure, but I think the z77x-UD3H is cheaper and just as good.
You can save $10 at newegg by going to a 1.5TB HDD over the 1TB (69.99 vs 79.99)
And your wireless card should work with just about any router.
Ok soooo is it better to go with the hd 7970 and the i5 3570k
It is not nice of you to change your question after you have asked it. :( BUt the original one, I have no clue if it is a app or actual wireless adapter (unless I am thinking of another thread, if I am, sorry).
And much better, but go for a GTX 670 over a 7970. At the 7970/680 level you are just paying for power unnecessary. At 1080p and to some extent 1440p you will be maxxing anything out there with a 670/7950.
Processor is a much better choice there. The i5 is all anyone needs for gaming. HT only adds a few frames on a few games, and it is not $100 worth of frames.
I would normally disagree with that above comment, but at his res, the 7970 GHz Edition is too powerful for 1080p.
Who says that? Maybe in 2-3 years are there games that a hd7850 can't handle at 1080p...
But doubt that, so I'm saying. Why not an hd7870 or a gtx660 ti and buy something with the rest of your budget ;p.
