Low Heaven Benchmark scores GTX 680
As the title says it, my heaven benchmark scores and FPS seem very low for my system specs (You can see my specs below on my signature) I was wondering if I'm doing something wrong or if this scores sounds about right. (Picture Below)
Would that have anything to do with your CPU having 2 extra cores? I'm not sure how cpu limited you would be at that FPS and settings.
3820 = 4 core / 8 thread so no i dont think theres that huge a gap between the systems, i just have a feeling mine might boost better... i average a clock rate around 1200mhz
It seemed right to me at first but since FuryRosewood is averaging around 70 FPS there is probably something going on.
Do you have the latest drivers? Have you checked GPU and CPU usages while running the benchmark?
Are you running the same settings as him? He has all the settings maxed. I usually just run it without doing any changes to the settings so I'm guessing that's what you did.
I averaged about 70...not sure whats going on there...might look into it more when im not half asleep..
what's your actual score?
470 gets a 746 with average around 30 maxed at 1280x1024 or so with my 960t @3.2 but was making popping noises and had a good number of graphical glitches where a house would disappear for a frame or 2. just love how it can kick my gpu's but in fps, but still doesn't stress it enough to beat my maxes from just cause 2 of 40C cpu and 61C gpu
That's going to be really hard to give a good comparison due to the different resolutions. I'll download it here soon and run it with my card at his settings and let your guys know what I get.
Ill have to run it again and save it..attempted to save and with the way the UI works i didnt actually save it i suppose. Currently playing WoW with the GF and it would be kinda rude to log and run the BM.
I dont know what your talkin about bro, but your score is right on target.
With my factory overclocked 680 Im getting 46FPS average with the max settings 1080 on heaven.
Awesome! Thanks for posting this.
I only had the card for 2 weeks so I wasn't sure. Given the scores above I'm pleased.
