I have switched to a windows 7 laptop and have found that outlook express is not available. I'm looking for a small app like express. Is there anyone with any idea's??
I know you can definitely set up multiple accounts on Thunderbird.
According to this you have to import the PST files into Outlook first and then have Thunderbird import Outlook's content.
I have tried Thunderbird and it works perfect! imported all from express that was needed, added 2 accounts and all works perfect. Thanks again for the suggestion...... Another problem solved. Thanks.
