Are these temperatures normal?
alexjb
Hi, I just built my first computer and want to check if all these temperatures sound normal please :)
I have no clue what to look for:confused:
OCZ SSD 128c/262f
Nvidia GTX 670 - GPU Core 47c/116f
ACPI: Temperatures =
TZ00 28c/82f
TZ01 30c/85f
it hit 128c while installing battlefield 2 and then I shut it down instantly, I opened up my case but the SSD feels freezing
A lot of time you can get incorrect temp readings from software, windows, and even the bios.
1. have you checked your termps in the bios
2. does your ocz have the most recent firmware ?
Thank you, I cannot seem to find the SSD temperatures in the BIOS, I think I may need to download the latest firmware, thank you I will try and give that a go :)
Some ocz drives can update the firmware while running, but others can not update firmware while the drive is being used as a boot drive.
