im going to get a Corsair HX series PSU I have a asus 670 (going to SLI some time in the future. Im going to have 3 lights inside the case in addition to the usual stuff. Should i get the 750 or will that not be enough? Thanks!!
You should be fine with 750W. It'll leave you plenty of overhead.
50W, so if you should oc, you'll have no anymore.
do you mean i have to be careful when i OC? because im planning on OCing my GPU and CPU a lot.
670-170W MAX TDP x2=340W, add OC, 370W for a nice big OC on each card
Board-50W Max (Usally)
What CPU?
RAM: Up to 15W
Other stuff doesnt matter.
And lets say a 125W CPU, plus a 30W OC for a nice big CPU OC.
So, a 650W PSU would work. 750W is great.
the cpu is Intel 3570k, and so i should go with the 750???
Nope, look here: http://www.bit-tech.net/hardware/cpus/2012/05/01/intel-core-i5-3570k-cpu-review/7
It uses 267Watt max when oc to 5ghz.
The max TDP shown on the specs isn't right. It's the voltage x the watts shown and you'll get it.
The max TDP shown on the specs isn't right. It's the Voltage x Current shown and you'll get it.
Power is volts x current, always has been. TDP is not the same as power consumed, its just the amount the device will give off as heat.
