CPU: AMD A8-3870K 3.0GHz Quad-Core Processor ($109.98 @ NCIX US)
Motherboard: ASRock A55 PRO3 ATX FM1 Motherboard ($74.99 @ Amazon)
Memory: Kingston HyperX 4GB (1 x 4GB) DDR3-1866 Memory ($24.74 @ Amazon)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($49.99 @ NCIX US)
Optical Drive: Lite-On iHAS224-06 DVD/CD Writer ($18.99 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($90.70 @ Amazon)
Total: $369.39
APU's benefit quite a bit from higher frequency RAM, so that's why I picked the 1866MHz RAM.
This build uses an AMD Processor with integrated graphics.
If you read my post then you'd know why I picked the 1866MHz.go for 8gb 1333mhz...
rest is good, you'll not get very much with 400$. But with this build, you can still get a gpu later
I don't share the same IP as randome, check again. Also, Controlling is my brother.Can I ask you a question? Why is it that you and the user that started this thread Randome have the same IP address? You also share that IP address with another user named _controlling.
