Good for gaming?
Lolman
Cost is 600$ NZL (410 USD)
All I wanna be doing is playing DoW II, LoL, Cmbt Arms etc.
Not hardcore games ;D
Its is pre-built.
System Specs:
Asrock FX1 Motherboard
AMD A6-3670 Quad Core 2.7GHz CPU
4GB DDR3 RAM Memory
Graphics and Video:
Dedicated GT 630 1GB GDDR3 PCI-E Graphics card
Core Clock 700 MHz
Shader Clock 1400 MHz
Memory Clock 1200 MHz
Process Technology 40 nm
DirectX11
OpenGL 4.2
Digital max resolution 2560 x 1600
Analog max resolution 2048 x 1536
Video Output: 1 x DVI, 1 x HDMI and 1 x D-Sub (VGA)
Sound and Audio:
5.1 HD VIA® VT1705 Audio Sound Card
Network and Communication:
Realtek RTL8111E Gigabit LAN Network Ethernet Card
8 USB Ports (2 Front , 6 Rear)
Storage and Drives:
1TB Seagate Serial ATA Hard Drive
Liteon 24x Speed CD and DVD Writer
Optional Expansion:
1 x PCI Express 2.0 x16 slot
1 x PCI Express 2.0 x1 slot
1 x PCI slot
4 x SATA2 3.0 Ports
You could game with that gpu, your problem is your cpu, which is not good for gaming. My gt220 is able to play most games medium and sometimes high, so a gt630 is enough. Get an A8 3870k, that one is better in gaming.
agreed.... but the 630 will be a bottleneck either way. might as well leave the cpu in.
No, that cpu and gpu will not bottleneck eachother, they are just all 2 limited in performance. Medium settings will go fine, I think the IPG are still worse then a gt630.
Price isn't too bad but probably not worth it. It is a pretty low-end system.
Not sure how well it will perform playing those games, you're looking at maybe low-medium perhaps on a decent resolution.
I would keep hunting and see if you can find anything better.
Processor and GPU are both too low-end for any serious sort of gaming.
If you can upgrade that cpu, you could play medium. I thought a gt630 was better then a gt220 btw? :P
I could build you a budget pc if you give me your location.
GT 630 is better but I owned a GT 220 once and it was a very low-end card anyway. Not really for gaming.
Yeah I think the GT cards are more for light gaming at low resolutions or streaming stuff. GTS and GTX are for gaming.
Hey I am from New Zealand, if you have some spare time could you please look around for a decent computer that is up too $650 NZ with atleast a trial of win7 ;D good sites are Trademe, PlayTech, Pbtech, Computerforum etc/
You may be able to order the parts from PC Case Gear which is a company based in Australia. They may ship the parts over to you. Not sure.
