ZeoTechCenter
So I'm helping my mother out who is a manager at a medical office, now I am having a hard time figuring out how they have their network setup.
Picture this scenario. You have two rooms.
In room one: you have a cable modem which is attached via Ethernet cable to a wireless router (Linksys WRT54G) this router has one computer attached to it and is broadcasting a wireless signal. This router can successfully connect to the internet.
In room two: you have a router (Linksys WRT54G) not connected to a modem at all. That port is empty. In the four lan ports you have 3 computers and 1 printer connected. I believe it is also broadcasting a wireless signal with the exact same settings as the router in room one. This router can also successfully connect to the internet.
Both routers appear to have identical settings and are using the default linksys firmware.
Other notes: The computer in room one can see all the computers connected to the router in room two.
If someone can please tell me how this is possible that would be absolutely wonderful as the router in room 2 needs to be replaced because port 4 is not functioning properly.
