converter
I have a converter. It says on the package: ATX P4 4-Pin male to EPS 8-pin female 6-inch long. My question is this: Can this be used backwards---EPS 8-pin female to ATX 4-Pin male? I want to convert down.
Yes. The port will only provide the power to the 4 pin side though. So you have a limit of power provided. But that is not an issue on boards with only the P4 connector.
