Gaming PC for a game like WOW
Well I am looking to build a gaming pc for a game just like WOW. I don't want it to lag at all and I want it to look good as well. I know components pretty well but I am not sure what I will need here.
What I have already:
250gb seagate 7200rpm drive
standard optical dvd drive
alienware case
coolermaster evo 212 cpu cooler
BUDGET: 700usd
I want:
atleast a quad core cpu intel/amd
60gb SSD
I want the gpu to be the best it can be on the budget
Thank you in advance and god bless.
Hx750 --> CX600
Hd7850 oc --> cheapest hd7850 from a good brand like, xfx, asus, sapphire, gigabyte.
Fx4100 --> i5 (is alot better, even oced the fx is worse) http://www.newegg.com/Product/Product.aspx?Item=N82E16819116781
Mobo --> http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653
Sniper ram --> http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Rest should be ok and in budget.
EDIT: I saw it's far below budget though, take an i5 3570k and an hd7870.
Hx750 --> CX600
All of this. Plus don't forget Windows if you need that.
Thanks guys and I got windows, I decided to go with the i5 3330 and hd7870
Sounds good. If you want to OC though, you'll need a K version of a processor. Probably the 3570K. Otherwise you can't really OC with the one you chose.
That is BS to a point. He could easily hit 4GHz with that processor with good cooling and depending on its exact BCLK overclock ability. Mine did 106 with no trouble. 107 was attainable, but was unstable. 105-108 is the average on the sandy and ivy chips.
edit. I am stupid for not researching. He could feasibly get 3.4GHz or so easily.
Now as I understand the non K edition of the processor you cant overclock. Or can you? Also do you guys think I should get the better video card with the non overclocking processor. Or the unlocked processor with the 7850 video card?
either will do you fine at 1080p. A 7850 is a strong card. It matches my GTX480.
You can overclock a non K CPU, you just can't overclock it as much. You will be limited by the stock multiplier if you go with a non k CPU, so get the fastest clocked CPU you can if you want to do it the "wrong" or "hard" way.
You can definatley get a tiny bit Cheaper PSU also the corsair TX 750W i just got was 104.99 CDN
Read previous posts, he is going with a CX600.
Yeah, the hd7850 should be fine if you're gaming @1080p.
Take the i5 3570k, so you can oc if you want it maybe.
Also maybe go for a better mobo then I mentioned, the Z77X-dh3 or Z77X-udh3
