yeh, you have to look to the singlethreaded. The phenom is beaten there...
That's a big point were amd has to work on.
It's still not accurate. Clock for clock the Phenom II is around the same as core 2 architecture, with some core 2 being a little faster BUT not a pentium dual core which is stripped of it's cache. Now take that into account, and then take into account my Phenom II was almost 600 MHZ faster, there's absolutely no way that a pentium dual core at 2.9ghz is faster than a Phenom II at 3.5ghz.
Now here's a semi accurate example, E6300 VS a 955-
http://www.anandtech.com/bench/Product/94?vs=88
Thats only a 400mhz speed difference, my Phenom II was nearly 600mhz faster....yet even at only 400mhz faster the Phenom II pulls way ahead over the pentium dual core in single threaded benches.
There's simply no way a Pentium dual core at 2.9ghz should be even close as fast as Phenom II at 3.5ghz, let alone beat the Phenom II thats just nuts.
Edit- Take a look, a Q8300 at stock 2.5ghz is pulling a 720 and my Phenom II at 3.5ghz is at 734. Absolutely no way. Q8xxx is around the exact same speed clock for clock as Phenom II, but I was 1 entire ghz faster! Q9xxx's are slightly faster than Phenom II but nothing ground breaking like nehalem and sandy bridge. So, in the real world, my Phenom II at 3.5ghz would be ~25% faster than a Q8300 at 2.5ghz, so roughly it should be around 900 points on your bench. And that sounds about right since a Q6600 at 3.2ghz is scoring 877 points, and Phenom II is easily as fast as kentsfield core 2 architecture.
