Have a Look at the new build !
Gamepsyched
Finally got everything running in Tip-Top shape with no problems. So without further a-due feast your eyes on the new setup.
YAY! New stuff!
The start!
Completion (FINALLY)
Top View
CASE
I am very satisfied with my new setup and can run any game on full settings, Everything is rocket fast and AWESOME!
And may i add it wouldnt have been so awesome without the help of some of you on this forum!
SO THANKS! hope you guys like
If you move your GTX 680 to the highest PCI Express slot, you may get better performance.
^:good: i agree that you should do this. also, congrats on the new build. looks nice, (except that card being on the wrong slot). the 680 is a great card. i have the 670 4gig version (ftw), and its amazing. enjoy
your top PCIe lane is x16 when you are not using any of the other slots. The one you are in is x8. Meaning that you are only able at most to access 1/2 the total bandwidth that you could in the top lane.
Exactly. That's why I'd move it.
Running it in a x8 3.0 slot is like running it in a 2.0 x16 slot. I do agree that it would be beneficial to move it to the higher slot but it will not be a massive increase in performance.
I moved it but now everything is all blurry and It doesnt fill the whole screen anymore... Still on 1920x1080 ... Whats going on?>
Did you reconnect the power cables? And make sure it is fully seated. Also if that fails, then try to reinstall the drivers (don't know if that will help or not).
Reinstalled drivers but still feels the computer is acting if it searches the other PCI slot first now.
Before when starting comp it would go straight to the login screen.
NOW after bios it will say power savings mode quickly (What it does when it gets no signal) Then 1 or 2 seconds later it will pop up DVI and start load screen. Not really a big deal but i just want to make sure i installed right and it is working at full potential
