What gives with pcs!!!!
I'm really fedup with my pc...I buy extra ram (now having 6gb ), a 2nd harddrive, and a bluray player...and find my pc is running slower than before!!!
I (think) my problem is power supply..only around 230w...my graphics card is a geforce 240..which...makes a heck of a noise and i think should be running on 300w..blame pcworld when i first bought the pc and they installed the graphics card for not checking!!!....
My problem though is....connections....Does it matter where I connect my 2nd harddrive?..is there a sequence...i mean..i connected it and it shows up and i saved to it etc..but a few days later...it disappears?..i reconnect..and it shows up again....but computer is slower...would it be not enough power??
My LG blurray player...the power leads..are too short..and Ive nothing to connect it too....other then..perhaps....a lead coming out of the back of my installed DVD drive....basically..Does it matter where you connect it up too...theres a bunch of wires ( about 5 of them differnet colours )...if i connect it to the only space I can..the wires dont head to the power supply but continue on to one of the HD....is that ok??? Or is my crud PC only capable of one device so i have to make a choice?
I dont mind getting a new power supply...PLEASE ADVICE...I have been told before..but NOW so weary...I mean the one I want needs to fit...and I dont want it to have a fan up at the top etc etc...and a new graphics card??? WILL ANY MOTHERBOARD BE ABLE TO TAKE A NEW POWER SUPPLY..AND CAN I INSTALL ANY GRAPHICS CARD??
If so...PLEASE ADVICE...at my wits end here...buget would be about £40 for power and £80 for graphics card. Although ideally want to do HD editing..the Geforce 240 works for my graphics..but clearly i need to upgrade..what is the next one up??
Advice PLEASE!! PLEASE PLEASE!!!
PACKARD BELL IXTREME M3720
6.OO GB RAM
640-BIT OP SYSMTE
PROCESSOR CORES 4
TOTAL SIZE OF HD - 932 GB
NVIDIA GEFORCE GT240
GRAPHICS MEMORY 3839MB
DECICATED GRAPHICS MEMORY 1024MBgarjobo
6.OO GB RAM
640-BIT OP SYSMTE
PROCESSOR CORES 4
