Internet browsers all acting very strange
It first started with IE where when I would search it would say something like "unable to locate site please reload later". Well I would hit the reload button right away and the page would be displayed with no problem. Then after doing this maybe half of the pictures would load properly and the others would not.
I just assumed it was IE. Then I tried Google Chrome and it did the same thing. Long story short I have tried at least 6 browsers and they all do the very same thing. Also since this started I run Netflix through my Wii system and I have to reboot it 3 times in order for it to work. Are these problems related? Anyone have an idea on what I should check? Thanks!!
I dunno if your problems are related to Netflix or not. But about your browsers, you're not the only one. It seems your browser needs to have its cache cleaned. If you see a common thumbnail for all the images, then it seems your browsers settings have changed. Either that or you need to clean your browser. I did this using CCleaner. It worked once, while the other time I had to re install Firefox.
If the problem persists through multiple browsers, than it's definitely the page or the internet connection. Especially if a newly installed one goes haywire. Yours, sounds like an internet connection problem. Try to talk with other clients of your internet provider, if they have similar problems, than it's clear. If they don't,send an email to the website support, because it's 90% sure that it's their fault.
Check your router and internet connection. I'd recommend disconnecting the router from the modem and then connecting directly to the modem, and then see if the problem stops.
Restarting both devices could help as well.
This is ridiculous. 6 browsers need their cache cleaned, eh? Highly doubt it, especially since he said he was experiencing problems on the Wii.
This is also ridiculous, it could be his router, which could be supplied by the company but still.
