Need some help on a computer build
lostsoul62
I'm going to build another computer period. I want to have decent tech support so here goes: I have a NZXT case and I called them up and was on hold for 30 minutes and was 2nd in the queue during that time so is NZXT the case I should consider
I was told that Asus motherboards are something I should stay away from because of their tech support.
Intel vs. AMD? AMD runs hot so is that something I should be concerned with?
Question about my Main PC: I push the power button and my case fans don't spin and my PC won't boot. Everything looks plug in; I took the RAM and Video card out and back in again. Could this be a bad power supply or maybe my motherboard is shot. It's a 19 month old AMD 955? Any help would be most appreciated.
Yes, try a different power supply first. If that don't work then try resetting the cmos by removing the cmos battery for a few minutes.
I kind of knew that would be what I would have to do but now I have to unbox my brand new 750 watt power supply and re-wire everything but I did get my fans to work. I'm going to do this tomorrow after a good night sleep. I'm just about ready to throw this computer in the trash so I'll try anything and removing the cmos battery will be a new experience. Thanks
