wolfeking
banned
Okay, thread is simple, build log, with some questions.
As you all know, from what I have said here, I own one of the piss poorest cases I have ever owned, the HAF912. Well I am going to go engineer on it and fix it, in the process right now. Got pics of what I have done so far.
Step one (no pics) Drilled out the Rivets, all of them. So it is basically a flat pack case right now.
To put it back together, there are some options, and I am not sure what I will do. Probably make that decision as I am assembling.
And with those I also have the options of leaving the HDD bays out or not. If I leave them out, then I have the option of using the hard drive space for a 2x120mm or 1x200 mm Radiator in the future. If I put the HDD bay back, then it looks bad and hinders cable management, while having more expansion space.
Step 2 (starting pics. more tomorrow when I go over it with the third and 4 coat): Paint Remover to strip it for the duraliner.
This is the first coat Friday night.
Currently done with 3 coats. Out of remover, but getting more tomorrow.
Step 3: Remove powdercoat. Failed, but 8oz later, here is what I have.
This is what occurred from advice given at Advance auto. They told me that Gasket remover would do the job just fine. Well 2 cans (8oz and $12) later, it is still not coming off very well. Hoping there is something better that can be done, or maybe go to a sand blast? Sand blasting is going to be expensive though, because I don't have the air pump, media, blaster, or respirator.
Step 4: (non linear steps) Apply Duraliner to internals. Only just started, so give credit for trying.
Plans on track to be done in ~ 3 weeks.
- Assemble using bolts, making it easier to disassemble in the future.
- Assemble using Rivets, which is not 100% permanent, but is more secure than bolts.
