Janeybeans
Hi from a newbie
I'm looking for some not-too-techy advice please! (I'm not a complete technical dunce but not too technical please!)
I do work from home which involves downloading audio files over an FTP server. This worked fine until I changed ISP and now the transfer speed is stupidly slow (around 4.5kbps) even though I'm now on a 30mb fibre connection (previously was on a 2mb 'ordinary' connection).
The ISP have been good and have done lots of testing and whilst they did find a problem with what the FTP traffic was being marked as (causing slower speeds) they've fixed this but I'm still having the problem. They're now pretty much saying it's not their network causing the issue (even though I never had a problem until I switched to them).
So, when they do finally say this I'm still going to be left with the problem of downloading at 4.5kbps when we're talking fairly large files - the ones I've downloaded today have been small at 10-15mb. A couple of weeks ago I had 3 files that were going to take around 36 hours to download (luckily the company was able to convert them to a different format without losing too much audio quality (I have to type what's being said in the audio so quality is key).
What things could I check that *might* fix the problem?
I'm using Filezilla to transfer and am on Windows Vista. I've tried turning off anti-virus.
I've tried accessing the FTP using a different user account, which was used with no problems by other clients but got the same speeds.
Nothing at all has changed either at this end or at the company end EXCEPT for changing ISP so I'm at a loss as to what to do (other than bang my head on a brick wall).
Thanks in advance
Thanks in advance
