Is there anyway you can run an ethernet cable from router to your room? The only other way to do this would be to get a wireless repeater/extender to extend your wireless but if you plan on doing any online gaming, it wouldn't be the best option.
Unless that modem is also a wireless gateway, you'll need a wireless router. What is the model of modem you have?
I recommend HawkHost personally.
Why not use Homeplug/Powerline?
If your house is a new build you'll have no issues with the earthing/ringmain in your house like I do![]()
You would need to buy a twin pack of powerline adapters, plug one into a power socket near the router, and attach it to the routher via ethernet cable.
Plug the other one upstairs into a power socket, and connect that to your desktop via ethernet cable
Both devices will then talk to each other using the earth cables inside your houses electrical circuitry.
I think there is a bit of initial configuration to do with the 2 adapters, but should be pretty straight forward and explained inside the manuals.
NewEgg sell a twin adapter pack here for $40
http://www.newegg.com/Product/Product.aspx?Item=N82E16833122328
There's no WiFi involved and it's essentially a cable run from your router to your Desktop PC, obviously the earthing will route back to your consumer unit like all electrical circuitry does, so it'll be longer than a straight ethernet cable from room to room, but inside a new house built it should be a fair bit faster and more reliable than going the wireless route, and also much better for gaming!
All existing Wireless/hardwired networks already functioning on the router will work as normal with this system installed too!
