ram issue
thanks weird thing is i sold the old one for 24 quid on ebay and only paid 15 for a better make and new strange people
is my motherbard crap in terms to words
You said p5g41c-mlx, sure its not the P5G41C-M LX. Its a Micro/uATX board. Shorter with less slots. 3 phase power setup. Its not crap. I would put it in between low and mid range board. Your not going to be doing any big time overclocking with it. But if its a good board it should run as stable as any on stock settings.
just woundred whyit is so small and myrig is only used for itnernet films and genral burning does play grid ok was better though when i had my 8800gtx 712 then my 512 one now thanks
ah right and yh that is my motherboard you mention just googled it stil about 55 quid so not to bad also thinking of gettign a 32-60gb ssd just to run my os off and a few bits would that help ?
SSDs have to have their place. In SATA 2 mode, you will boot faster, and transfers will saturate the bandwidth faster, but you will not see much difference in day to day activities. In SATA 3 mode you will be better off, just faster than SATA 2, but you can not just do everything like you always have done. You need a secondary platter drive to store DATA on or you will degrade your drive fast.
Personally, unless you are using it in a laptop (I have not read all 3 pages yet, so not completely sure) for heat reasons, or for battery reasons, I would stick to a HDD. The differences are not worth the cost if you are not fully committed to it.
