Getting a new Vishera 4300
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819113287)
Seeing as I'm upgrading from a Core 2 Duo, is it a good idea to order another 120mm fan, or should it run at roughly the same temp? Currently have a tower with plenty of space, one sys fan, PSU has a 120mm, GPU has 2 fans. Never had a problem with heat before, computer was purchased prebuilt, I added in the GPU and PSU.
