hi is there any good softwear out there to speed up my laptop before just going and getting a new one haha.
and if anyone has any other good softwear worth having in mind be glad to hear it thanks![]()
You can uses AVG PC TuneUp, this sort out your registry, finds any broken links, optimizes your startup and defrags your computer.
You can also use cCleaner. This get's rid of all your temp files etc from your browsers and software and also fixes your registry.
I do recommend you SpyBot Search & Destroy. It's free and it gets rid of spyware.
Use MSCONFIG.msc to remove any unneeded start up programs and increase cores.
Is this a programme that i can download or is it already in windows ?
Cheers mate
There's nothing quite like taking a new laptop computer out of the box for the first time. It boots right up and everything from navigating the web to launching different programs seems to run at lightning speed.
Cheers mate
