Hi,
I just completed my first build yesterday...
MB: ASRock Z77 OC Formula
CPU: Intel Core i5-3570K 3.4GHz Quad-Core
SSD: SanDisk Extreme SDSSDX-240G-G25 2.5" 240GB SATA III
HDD: Western Digital WD VelociRaptor WD6000HLHX 600GB 10000 RPM 32MB Cache SATA 6.0Gb/s 3.5"
So anyway, if I remember correctly, I had a bit of trouble the first few attempts at installing Windows 7. The "Starting Windows" screen would freeze and I had to press the reset button a few times before it worked. The installation worked after that and there were no problems with any reboots after that. I had only installed Windows 7 on the SSD though so I later tried to follow this tutorial to put the HDD to use. The "Starting Windows" screen kept freezing.
I tried that at least 15 times then I gave up for the night. About 12 hours later I tried again and it installed without a problem. This time, however, the freezing would now happen on bootup and not just when installing. I disconnected the HDD to see if that would fix the problem. It didn't so I disconnected the SDD and using only the HDD, I reinstalled Windows and it's working without a problem (but slower without the SSD).
Does anybody have any ideas what the problem is? It looks like there's some compatibility problem here. But when just running from the HDD, the SSD still shows up in "My Computer" and reads and writes seem to be working so I don't think it's a problem with the SSD alone.
