Discussion/Beta Testing thread - Black Hole
Yeh maybe, but try out other benches that take your cpu to 100%. You'll always have an improvement with lower latency...
I've never seen that much swing, almost 10% score drop going from 1900 to 1500mhz ram speeds with no other changes is not realistic.
I've seen as much as 2-3% variation in other benches. Most benches that test CPU performance have little to no affect to ram speed changes.
"most" yes, I can say mine does. And I think I gonna let it like it is now.
I just ran Wprime and got a 1% performance difference in 1500 VS 1900 ram speeds same timings.
SuperPi is known for having improvents with ram speed increases, but I've never seen more than 5% difference with that bench. Your new beta is double that! I don't think this is one you should release.
K, try previous beta. I only changed scoresytem :P
Why is no one taking a CPUz with their screenshot? Come on people, like we all know what clocks you are running at....
4.4ghz^^
new version is ready, I only couldn't make a code to solve the turbo clock. Only the base clock. So people will need to be honest about there clockspeed. I'll be watching to reasonable clocks though.
hold yourself ready!
If this is from the pre-release one, you can just post it in the offial sticky
Btw, if you click the button "post your scores", you can just send it to database after filling the blanks.
No, all programs that are running in background as of my every day life.
Was I suppose to turn anything off?
without turning anything off i ran it again after unlocking my 2 cores and it seems to scale perfectly, went from 2100 to 3176 and 2060 to 2070 which are close enough to sum up to the background tasks which i didn't turn off, avast, steam, origin, msi afterburner, pretty much it.
total is like 5236 or something like that, i did submit it to you both times i ran it, locked and unlocked.
